So what's wrong with motor mount spacers in your opinion? My grease zerks were hitting the pan also on lock to lock, so hitting the drag link and bending it slightly is ok?The brake line will be a problem. Even Pontiac had a different brake line route when using the RA/HO cast iron manifolds to avoid heating the brake line. Most brake fluid boils around 450° and the header tube will be above that temp with the pedal to the metal. I would want an inch of clearance.
The rag joint has plenty of clearance. We have a few cars in the club that the pins on the rag joint almost touch the header tube and they haven't had a problem.
As stated above, solid mounts are asking for trouble. First look it would seem that the engine wouldn't pull against the solid mounts any harder than the rubber mounts, but the problem is the nasty flexing the frame and cross member exerts through the mounts. Our old frames are really mushy. Look at it like a large lever twisting and pulling on the side of your engine block. The rubber or poly mounts absorb the twisting while the solid mounts put the stress right into the cast iron block.
The poly mounts have a low melting point. We ordered out one of the first sets that Butler had available and watched the polyurethane drip off the mounts on the test stand. Granted, temps are a little worse on the stand since there is little air movement, but it was still pretty strange to see.
Not a big fan of engine mount spacers unless the pan itself is sitting on the crossmember, but that is just my preference. There is a cure for the drag link touching but I'm a little hesitant to post it since getting carried away can lead to a big headache. When engine is in position and drag link is lightly touching the bottom of the pan, simply whack the drag link itself towards the pan. All you need is an 1/8" and you are totally safe putting a 1/4" dimple into the pan. Aftermarket pans are fatter in the bottom front and are down farther. Go 1/2" and you will have the crank counterweight skimming the pan. Clearancing works great but you can get carried away. We've probably clearanced over two dozen pans without a problem.
I believe I'm taking @PontiacJim advice on staying away from solid mounts.I think the rubber mounts will do that and maybe it will have more clearance once the trans is bolted on top the crossmember. I think the motor mounts are more towards the front of the motor causing it to sag backwards, I would probably block the motor up taking the stress of the mounts if it's going to sit for an extended period....might be worried about nothing I hope. I see the supervisor is camera shy 😉
The jury is still out, but I will be taking @PontiacJim advice on staying away from solid mounts.I think the rubber mounts will do that and maybe it will have more clearance once the trans is bolted on top the crossmember. I think the motor mounts are more towards the front of the motor causing it to sag backwards, I would probably block the motor up taking the stress of the mounts if it's going to sit for an extended period....might be worried about nothing I hope. I see the supervisor is camera shy 😉
Ya I think that's a good idea, it's not an all out race car right? I bought the torque lock mounts the one side is bolted through then surrounded by rubber.I believe I'm taking @PontiacJim advice on staying away from solid mounts.
Between the advice here and those of Ames techs I may purchase one of their upgraded kits for peace of mind. I'm holding up my resto with this decision, but I refuse to ever remove these headers once the body is on.
Between the advice here and that from Ames i may uograde now because these headers will not be coming off after the body is on.
@Baaad65 ...I'm going to be staring at the car in the garage with a beer in hand more than driving--#never mind racing!Ya I think that's a good idea, it's not an all out race car right? I bought the torque lock mounts the one side is bolted through then surrounded by rubber. View attachment 163362 View attachment 163363
I'm sure a lot of guys here are jealous that you're getting to install headers with the body off 😉@Baaad65 ...I'm going to be staying at the car in the garage with a beer in hand than driving--#never mind racing!
The engine is moderately "built"--forged internals, port/polished heads, bored .30, 274H comp cams. I believe the builder said it should produce ~485hp at the crank
Well--im happy my internet friends cautioned me before I slapped the body on first.I'm sure a lot of guys here are jealous that you're getting to install headers with the body off 😉
Nice, ya I wouldn't want to screw up and have him/her after me 😉Well--im happy my internet friends cautioned me before I slapped the body on first.
My coworker keeps me in check when I screw things up.
I remember seeing this same information somewhere...now where could that have been...oh ya way back in post #47 🤣Install the bellshousing, trans, mount, and crossmember. You don't have to install clutch, linkage, shifter, etc.- just the basics. Then see if the pipe hits. With only the engine mounts, you won't have any idea of clearances as the engine will drop back when it hangs. Mock up the needed items and then you will also know if shimming will be needed or do anything for you.
If you want to check the angle of the engine, get the frame level front to back first. The AMA spec for the 1967 GTO engine installation angle is 4 degrees 42 minutes, or according to an online calculator = 4.7 degrees.
The engine will hang down without a trans hooked up. I would mock that up before doing and clearancing workAll information is helpful. I'll have to wait until Monday to speak with Butler/Ames.
I realized my last video displaying my concern was 9 seconds.
Below I attached a longer version for all to see for theirs an mine future mods.
This was actually mentioned back in post #39.I remember seeing this same information somewhere...now where could that have been...oh ya way back in post #47 🤣
Must be the motor mounts used mine drops towards the rear significantly when trans is outWhen I did my TKX install, my engine sat unsupported for two weeks and it didnt move. When shimming my trans mount for the drive angle, I hit the extremes of the range of motion.
In the end, it was only the rag joint that hits, and only when the steering is in one position, and the cam's rough idle is making the motor bounce.
If even needed, one other option may be to safely use a small spreader or the like below or even a brake piston spreader with rubber shims to prevent marring can work to nudge the pipes a 1/4" or so.All information is helpful. I'll have to wait until Monday to speak with Butler/Ames.
