I've been looking around Ebay for a 400 to put in my project. Some of them mention whether they were linked to a manual or an automatic. Does it really make a difference? I thought if you were running an automatic you used a torque converter and if you were using a clutch you just intall the proper flywheel. Your thoughts?
If you're restoring a car and looking for correct block codes, it matters.
If it's not a "matching" question, you have a lot of flexibility!
If you're installing an automatic, replace the flywheel with the proper flexplate.
If you're running a manual trans, verify that the crank has been drilled to accept the pilot bushing.
Most Pontiac cranks have a stepped hole to accept the pilot bearing/bushing.
Also; if you get a manual trans engine, make sure the old pilot bushing has been removed before you re-assemble your engine.
You want to avoid this issue:http://www.gtoforum.com/f50/pilot-bearing-stuck-crank-25621/
Ya, I can't afford 'numbers matching' ;-)
Just checking as I know little to nothing about Pontiac engines and was puzzled by the 'automatic' comment.
Thanks for the response!
