2005 with factory 17's - never seen winter or salt
Drivers rear wheel has discolored and looks light gold in comparison to other 4 wheels. It also has a bunch of little cracks like it has a clear or protective coating that is failing if your up close to it.
I cleaned it with wheel cleaner many times and no change.
Is there a coating on the wheels and what is it?
Anyone know what the issue might be, if this is common (must not be as I couldn't find anything in forums on)
Also looking for a way to fix myself or place hopefully in MN to get it refinished?
Might be cheaper to just buy a used on but mine is fine other wise and I prefer to not be wasteful.
Thanks for your time!
factory 17s are painted alloy...(probably clear coated as well)...usually when I see the goldish color it is from brake dust that wasn't removed (can be corrosive) and some wheel cleaners, especially when put on a warm or hot wheel can etch the finish...
If one of these is your issue, the wheel refinisher should be able to fix you up for not a real lot of cash...good luck and let us know the outcome...
Bill
Ok so painted and then cleared - good info!
Now I have something to work off, I'll make some calls this week.
Side notes:
Wheels are always cleaned with Turtles Wax Ice car wash when I wash the car and never have left brake dust on. Only used Mother Tire car wash after discoloration issue started which I like for my truck rims. Yeah some stuff it to abrasive.
I did get some salt slush on the wheel last winter in the garage it was parked next to my truck and I stepped in some slush pile that fell of the truck and splashed that rim and tire only, I washed it off immediately with water but can only figure that caused the issue if it is a painted finish.
Thanks!
Thanks!
I drove my car through several winters and rarely washed it when it was cold. My wheels didn't have these issues. Sounds like a factory defect.
Eitherway, I'd get them powdercoated. Probally will cost the same as having somone come out and do an 'okay' job on site.
