I am trying to gauge interest in a programmable shift light module that is specifically designed for stealth installation. This particular shift light consists of a super bright 3mm LED that is available in 5 colors – red, blue, white, green, and amber. It is recommended that the LED be mounted in between the A-Pillar and the headliner, and aimed right at the driver’s eyes. In the GTO that I tested the module in the LED wasn’t noticeable at all until the light started flashing at the preset shift point! And, since the LED is at eye level it is detectable in your peripheral vision so you never have to take your eyes off the road!
The module is pretty easy to install, consisting of four wires – switched power, ground, tach input, and programming input. The switched power and tach signal can be tapped under the dash, near the clutch pedal, and the program input and ground were connected at the OEM TCS switch. The TCS switch was used because the programmable shift point is programmed though the OEM TCS switch! There are absolutely no switches, dials, pills, knobs or anything else on the shift light module, just the TCS button.
This shift light is produced by a small company that has been in business for over two years. They specialize in custom niche electronics. The module will come with a ‘no questions asked’ warranty and will cost around $75 shipped. Technical support would be available through Email and through a dedicated online support forum.
If there is enough interest the company in question will become a sponsor of this site, and offer members of this site a promotional group buy price. If you are interested in either purchasing this module or in hearing more about the module please post up!
Thank you,
Kevin Pierson
Thank you,
Kevin Pierson
