i read that nitto nt555r drs are the only drag radial that will tuck without fender rolling. i got the 275s yeterday with the same rim dimensions of the stock ones and its rubbing...n e ideas...or am i s.o.l?
There is a tool that is bolted on your rotor in place of your tire useing your lug nuts and then the tool has adjustment to increase the angle of the tool. It's got a roller wheel at the point that makes contact with the inner fender "lip" You start rolling it along the inner fender wall, increase tension, and roll again, repeat until the desired "roll" is achieved. When done correctly it looks completely stock. I know it doesnt take very long, but problem is finding a tool/shop that has one. My buddy bought his from a auto body shop. I hope this helps :cheers
