As summer time is here and we pull out our cars to get in more cruise time or hit the car shows, the one thing many do not consider is "What if?" Mechanical problems can happen at any time and you never know what they will be. I like to keep a few general items in my trunk like the cap/rotor, coil wire, spark plug/spark plug wire or two from my last tune-up, and an extra fuel filter. Ignition & fuel are probably the two most areas you will run into problems out on the road - at least in my experiences. I always have a tool box in my trunk with the basic tools to get the job done in a pinch. Then I have AAA coverage which includes the 100 mile tow package. Many insurance companies offer roadside assistance & towing, so it is a good thing to have and can add security to your drive should the need arise.
But what if you have that unexpected situation which could take out your car? The two most unfortunate situations are a fire under your hood or an electrical fire. Most are not ready for such a catastrophe and these two things can destroy your beloved ride.
I always add these 2 items to all my "old" rides - a Battery Disconnect and Fire Extinguisher.
I add this style of Battery Disconnect shown in my pic. There are other types, but I like this one. It is designed to fit on the negative battery post, BUT, in my application I gently spread the clamp a little wider and fitted it to my positive battery post and then attach my positive battery cable to the post found on the Battery Disconnect device. Either way, you want to make sure that it does not strike the body or any hood bracing when you shut the hood.
The device looks like something you would see in your science class or a Frankenstein movie. You simply rotate the arm to complete the connection from the positive cable to the positive terminal on your battery. To disconnect power, simply rotate/pull the arm up. FAST and simple as it should be if an electrical wire begins to melt down, your starter solenoid sticks and won't disengage, or a hot 12V wire rubs through or melts down from exposure to high heat like those wires near the exhaust manifold.
I have literally watched a wire burn up under the dash of one of my cars - someone had messed around with the wiring adding something that was no longer on the car. I suspect it grounded out at the time and as the wire got red hot, set the plastic wire covering on fire as it melted it. It won't go out by blowing on it - the electrical power needs to be disconnected so the short that is grounding the wire out is also disconnected. Trying to run to your trunk in a panic, sort through your tools to find your wrenches, and undoing that really stuck positive battery cable might be all the time that is needed to really fry all those wires under the dash or engine compartment or worse......set something ablaze which could have happened to my car if it simply wasn't a hanging wire and one that was deeper into the dash and maybe even up against some insulation.
Additional benefits include: Stops unwanted battery drain, can help prevent theft, tampering and unauthorized use and also improve safety and security of stored vehicles. I got mine at AutoZone and are reasonably priced, especially when you think of the value of your car.
The next item is a no-brainer - a Fire Extinguisher. Its too late when the fire has begun and generally you won't know until you see the smoke and by that time it may be too late. Most fires occur under the hood and are gasoline caused like a rubber hose lets go spraying gas all over or your carb float sticks pouring gas out the vent and onto your hot engine all the while as you are still driving and the car starts running a little "funny." You may smell the gas, but it could be too late at that point. Again, you could have a wire fire and the combo of a quick battery disconnect and fire extinguisher may minimize the damage or keep you from having a total loss of you vehicle.
There are many brands of fire extinguishers and they come is various sizes as well as quality, content, and different pricing. I got just a basic one from my local auto parts store. It is an Auto/Marine extinguisher and rated for A/B/C class fires which includes electrical and gasoline.
Most extinguishers like mine are a dry chemical. From what I have read, it'll put out the fire, but may ruin things like interiors or make a real mess of the engine compartment. BUT, the important point is that you save the car. The first job of most extinguishers is to interrupt the combustion process. The second thing that is almost as important as the first is whatever is burning needs to be cooled as there is a good chance it could reignite. The dry chemical extinguishers help to coat the surface with material that does two jobs, interrupts the combustion process and to coat/insulate the surface to prevent reflash.
Things to remember:
Opening the hood to gain access to an engine fire will add oxygen and increase the fire instantly--you could get a face full of fire.
If your car catches fire while moving, try to get it stopped safely, in a safe place, shut off the ignition, and apply the emergency brake. This makes it safer to exit the vehicle. A burning car rolling down a road or hill is very scary.
If you do get the fire out initially with an extinguisher, chances of it reigniting are very likely. The heat is still there to ignite vapors from fuels and super heated combustible materials. Be aware of this and if need be, nearby dirt/sand can make a good source to throw on a fire to put it out.
Smoke from car fires can be extremely toxic and dangerous.
If the fire gets out of control, don't try to do any more - call 911. The heat from a car fire is extreme and you need to get a safe distance away. Let the professional fire fighters and their equipment do their job.
You can do your own research on other fire extinguisher options, but you should have as a minimum a dry chemical ABC rated extinguisher in your trunk and easily accessible should the need ever arise. :thumbsup:
Fire extinguisher
Good advice about the fire extinguisher, but spend the extra money and get a Halotron extinguisher.
Dry chemical leaves a big mess and is highly corrosive.
Banned
Same one I bought, it is worth the extra money to go with Halon to avoid the mess you will have to deal with left by a standard ABC.
I actually bought two, one behind the seat and one in the trunk in case I knock the fire down and need another to finish the job.
I went to a local car show and they wouldn't let you enter unless you had an extinguisher in your ride.
Check EPAY I got mine for 112$ shipped
I agree on the non dry chemical extinguishers. I do minor tool repairs for our weld shop. We had a field truck have a dry Chem extinguisher go off in a enclosed storage side box. That stuff is VERY corrosive! We ended up just throwing away a 110 volt mig maching. It wasn't worth the money to unfreeze the motors and unplug and remove all electrics and wash out everything. With in a few days it was eating everything. The portable air compressor I got working with a good blowing out followed by the garden hose and coaxing the motor to turn. The expensive Miller xmt fried when they plugged it in to use it the same day. I was a huge repair bill. I guess I'm saying is its worth the extra $ to get the better ones. But any is better than watching your stuff burn.
Sent from my SM-T230NU using Tapatalk
OK, after reading the comments I did some further research that I am adding. The reason was the cautions noted about the corrosive nature of the Dry Chemical extinguishers - which I was not aware of. It seems the ABC type are the worst offender, while the BC type appear to be the best choice if going with a Dry Chemical extinguisher. Cost is always a consideration, but even with the negative side of the chemical extinguishers, it is still better to have something than nothing at all and watch your ride go up in flames.
DRY CHEMICAL FIRE EXTINGUISHERS are designed to stick to everything to retard flames. The dry chemical extinguishers insulate class A fires by melting at approximately 350 to 400 degrees. The powder coats the surface it’s applied to, breaking the chain reaction of class B fires, and is said to be safe for class C fires because it is a nonconductor of electricity.
Class A - Wood, paper, plastics.
Class B -flammable liquids such as gas & oil.
Class C - electrical equipment.
Class ABC extinguishers contain monoammonium phosphate or ammonium phosphate which is very corrosive in presence of moisture. It will damage electrical equipment and can corrode metals. The monoammonium phosphate is more effective on class A fires (wood, paper, etc) because it melts and forms a crust on the fuel.
Class B-C extinguishers contain baking soda,sodium bicarbonate and is non-corrosive. This is a better choice for automobile users.
Dry Chemical Fire Extinguisher Clean-Up.
1.) First, Sweep or vacuum any residue that has settled on the affected area. Avoid using only water for cleanup - the powder becomes pasty (and corrosive) when wet or exposed to moisture.
2.) To break down the silicone in the dry chemical, spray the affected area with a solution of 50% isopropyl alcohol and 50% warm water. Allow the solution to penetrate the residue for a few minutes, then rinse with warm water.
3.) To neutralize monoammonium phosphate based dry chemical, wash the affected area with a solution of hot water and baking soda. Allow the solution to treat the excess agent for a few minutes, then rinse with warm water. Wash the area with a mild soap and water solution; then rinse. Blow the area dry to remove excess water.
4.) To neutralize sodium bicarbonate and potassium bicarbonate based dry chemicals, wash the affected area with a solution of 98% hot water and 2% vinegar. Allow the solution to sit for a few minutes; then rinse with warm water.
A short You Tube video telling how to clean-up after a dry chemical
The Clean Agent Extinguisher
A "Clean Agent" is "an electrically non-conducting volatile, or gaseous fire extinguishant that does not leave a residue upon evaporation." Clean Agent Extinguishers use both halon and halocarbon by interrupting the chemical reaction component of a fire. The extinguisher is mainly used on Class B and C fires. Their non-corrosive and non-conductive chemical makeup makes them ideal for aircraft usage.
Halon 1211 is an excellent fire extinguishing agent, as it is a streaming agent with low toxicity, a low pressure, liquefied gas, and effective on all common types of fires, A, B, and C. It is no longer being manufactured although still available for use. Halotron I is the replacement extinguishing agent. It takes a larger volume to get the same ratings as 1211 has.
Halotron 1 is a "clean" fire-extinguishing agent intended to replace Halon 1211. Halotron is a safe, effective, environmentally acceptable replacement for Halon 1211. It is discharged as a liquid that rapidly evaporates. Halotron 1 is a proprietary three-component chemical blend.
