1 - 9 of 9 Posts
whenever I get my rpms high usually around 3~4k and i let off of the gas and have the engine run down sometimes the dashboard area starts to shake violently. its not like a stall. When the Rpms get to about 2k it stops and my car is fine. Can it be something to do with the drive shaft like the U-joint? Any help would be awesome!
A bit more information would be helpful!
What year and is your car Auto or Manual? How many miles? Fluid service history would help!
When the car first starts to vibrate, put the car in neutral and see if the vibration stops or continues.
What does the car do when accelerating from 2K through 4K?
2006 manual 166,xxx. oil has been changed about every 3k miles. changed tranny fluid probably 4 months ago. vibration does stop when putting into neutral. cars runs perfect while accelerating no sounds,doesnt feel sluggish, and no vibrations. I heard it could do something with the steering rack due to a bad bearing.
Sounds like you need to get in on a rack and start looking for loose parts!
Drive-shaft
Steering Rack
Engine pulley ...bearings
Suspension parts... bushings and etc.
At 166K+ there are bound to be some parts that are worn out and never been changed. Some mechanics use a stethoscope to find subtle worn out parts by listening for vibrations.
Defnietly check the gulibos & carrier bearing on the driveshaft for play or rips , lol why those are installed are beyond me , never saw a car or truck for that matter in my 21 years as a tech have that type of thing on them except on a gto ? even the type of rubber dampeners on the foreign cars are better designed... also have you checked your strut bushings?
1 - 9 of 9 Posts
