RIP (12/27/60-7/18/15)
the fuel fitting on my new carb sticks out , and I have a straight fitting going to a rubber fuel line, when the hose is on, it will be up against the upper radiator hose.
(no one has the right size 90 either................)
How big,if any,of a problem is this?
thanks as always
:agree If you can't find the proper fitting, and the fuel line must touch the rad hose, secure a small piece of black foam pipe insulation (or the likes there of) to the fuel line for ;1) insulation from heat, and 2) as an anti chafing measure. Eric:cheers
I think the vendors sell the proper outlet line. It's a 90 degree bend to the driver's side. It needs to be there in order not to be "rigged". If you get the right line, you'll be glad you did.
