I am working on a design using fiberglass/plastic that would route the air from the scoops over to the airbox. Once I finish it, it'll be "open source", so to speak, meaning I'll give it to others to use/improve as long as they give their improvements to the GTO community.
One thing you can do until someone does come up with a way to get air to the airbox is to pull the rubber strips out, that is what I did the first day I got the car. It would allow a bit of cool air into the engine bay. I didn't see any performance increase from it. My intake temps (according to the Predator's logs) stay only 5-10 degrees above the ambient outside air's temperature.
Realistically, it shouldn't be too difficult to make the air go from the ports to the airbox...just a bit of clever fabrication.
