On the Gas Tank Fuel line connections, there are two connection, One is supply and the other is return (?). As you look at the connections one is at 6 o'clock the the other is at 3 o'clock. Which one is the supply?
Thanks for the input.
Jim
:cheers
I believe the 3 o'clock is the feed. Can you pull the whole housing apart and look?
