1 - 18 of 18 Posts
First, let me say I have read the sticky 3 times, thouroughly.
Currently I am running 2.73 gears in my stock 68 GTO/400, with a 4 speed transmission. I am scheduled to get these gears swapped out in three weeks. I have already bought 3.73s, but after reading the sticky on Gear Ratios, I want to be able to drive it both on the highway and have some power in town, so I am changing directions and really think I want 3.23s or 3.55s. The problem with my current gears is that I own a muscle car and it will not smoke the ONE tire. (I have bought an EATON posi 3 series carrier to go with my new gears.)
My goal is not for the car to smoke both tires forever, but I would like for it to chirp them a little bit, and then set you back in your seat. (That is what a muscle car is right?) This car will not be raced, but it feels like a dog right now with these gears and I don't like it. If you have experience with these gears, and have an idea what effect they would have on this car, please help!
Split the difference....3.36......3.55 is a little stiff for long highway trips, although it is a great gear ratio for a 4 speed GTO
My favorite gear for a 4 speed GTO is a 3.23. My own 4 speed '65 has a 3.36, because that's the tallest gear I could use with my carrier. 3.36 gears are ok...mine cruises 65-70. That said, my heavy, low compression, TH400 '67 GTO convertible has a 2.56 limited slip and it FRIES the tires. Something is wrong with your tune or combo. Seriously wrong. The tallest gear Pontiac put in their 4 speed GTO's was the 3.08. A 2 series gear with a 4 speed isn't the greatest, so yeah, you should re-gear. But get the engine checked out!
Currently I am running 2.73 gears in my stock 68 GTO/400, with a 4 speed transmission. ...
Have you tried this formula?
1) Depress clutch pedal
2) Select first gear
3) Tach to 3000-3500
4) Side-step clutch pedal and simultaneously...
5) ...Bury the loud pedal
:D
I have a 3.55 on mine and it will cook the tires at the drop of a hat. It's great for crusin' around town or going on a country cruise. 2500 rpm at about 50-55 mph. rpm's do get a little high on the interstate though, 3500-4000 rpm @ 70-80 mph. I have a TH400 3-spd auto. trans so my set up is differant than yours. Sometimes I wish that I did have a higher gear, like a 2.93 mabe, because gas is starting getting expensive again. Hope this helped.
BearGFR, you are right on. I baby all of my cars, and would feel guilty popping the clutch. My friends insist I do, but it is my baby... I am almost 100% certain it would light them up like that, but I don't want to do it that way. And frying my tires off is not what I want either.
:agree with GeeTee check your tune, that car should not have a problem barking the tires from a get even with the tall gear.
Ohhhh tayyy... I wasn't advocating the procedure, necessarily - just offering a solution. ;) I'd have a tough time doing that on a regular basis myself.
Discussion Starter #12
OK, my car is running night and day different. I did a couple things and they both helped equally. Thanks to lars and the sticky he provided on tuning your car, the first thing I did was bend the accelerator back. WHOA! I don't think the secondaries were ever opening. The other adjustment was the timing. When I first got the car it was set at 6. I then advanced it to 12 and it ran a little bit better. The next time I said what the heck and bumped it up to 18. And WOW! The guy I bought it from said he was messing with it to get it to run better, but he admitted he was not a mechanic. I am guessing when he put the distributor back on he did not get it stuck in there right, so it may only be advanced 10 degrees or so, but I don't really want to mess with it because it is running perfect. Also these 2.73 gears now feel amazing, but I am probably going to go with 3.55s and not the 3.23s because my friends are begging me to go with the 3.73s. Still not sure...
Thanks!
Good deal! Glad to hear it's better. If your friends are Chevy guys, ignore them. They don't understand the power band of a Pontiac and the torque it makes down low.
Fr'instance. The 461 I built for my 69 makes 493 peak HP, but the real story is the torque - it makes 540 lb.ft. at a measly 3200 RPM. I've got 3.50's in it because that's all it's going to need - and even with those I'm just hoping I'm going to be able to get it to hook...:D
It all depends on how often you drive the car, what KIND of driving you do, and what you are expecting from your car. When I was a teenager, and gas was 51 cents a gallon for leaded premium, and the speed limit was 55mph, I thought the 3.55 gears in my '66 GTO were great. I drove that car everywhere, buzzing along at 55 mph, sucking cheap gas. As I got older, and time went by, and the new cars got overdrives and the speed limits went waaaay up and road noise went waay down, 3.55's lost their charm. 3500-4000 rpm at 70mph wasn't any fun. Mind you, this was daily driver/commute car 100 miles a day, not "fun" driving. I changed my '65 gear to 3.36 in 1990, and it works very well with the 4 speed. It runs "like a GTO", and is cruisable. I personally would not run 3.55-3.73 or shorter gear because I don't require one for the kind of driving I do. Pontiacs tend to do better at the strip with a low 3 series gear, do to traction problems and huge torque. I can't believe some of the et's guys are getting with 2.56, 2.73, 2.93 gears. Really impressive. As always, build it the way you want it. I've been driving mine constantly since the '70's, and have found that 3.36-3.23 works for me with a 4 speed and 2 series gears are great with an automatic. Gas is skyrocketing, but I drove my '67 160 miles on Sunday, and got about 20mpg. Your mileage may vary!
Discussion Starter #15
I have to say I was extremely shocked at how hard the 2.73 gears were pulling yesterday. Maybe I will go with the 3.23s. I am so confused right now...
With a good tune and a steady pedal, I get 18.5 mpg on my 67 with the HO and 3.55's and 4 speed. (keeping the speed around 62, though!)
1 - 18 of 18 Posts
