Every time I try to open my glove box I get frustrated. The door does not pop
open when I press the lock button. I have to press the button and pry the door open with another finger. I Know there is a small spring on the hinge that is there for some reason but can't figure it out. Is there some type of adjustment needed on the lock or the door itself ? If anyone has solved this problem please let me know how. I am currently refurbishing the entire dash but feel like putting a 9mm to it. :shutme
Thanks,
Miami Ragtop
There is a spring in the hinge pin at the bottom of the Glove Box door, yours maybe broken, or weak......common on 66 and 67. Eric
do you have the two little rubber bumpers in it on the top, w/o those it will not POP open. also as Eric said if your spring is missing of weak it may catch
lubricate the latch also. :cheers i had a trunk lid that no matter how i adjusted it wouldnt close without slamming. one little shot of wd-40 and it closed like butter.
