any of you guys out there have any experience with engine test stands? Any good models that are decently priced? I don't want to spend a ton on it but I am really looking at getting one so I can run in my new engine when I get it (mostly to see if it got ripped off or if anything is wrong with it).
I have found one that is a very good price but I can't find any reviews on it. here is a link
Amazon.com: Larin METS-1 Mobile Engine Testing Station: Automotive
There are lots of other that I found for 2 g's but that is to much for me to spend since I have plenty of other parts I need to finish the car.
Thanks guys
Scott
Can you weld? Not really much to it. Could probably get one built for less than 2k also. Any fab metal shops around? I have seen medical equipent stand used as one too. A few gauges. Toggle switch and starter button. Thats a fairly good price on the one you linked. Pretty much has it all.
I can kinda weld. but I would spend as much buying the welding equipment as I would buying a cheap test stand. But I'm sure I could find a few fab shops that could put something together, pretty good idea.
Another option for you, depending on where you're at with your project: put the engine in the car and just rig up direct "hot wire" connections to the battery for ignition and starter. I broke my engine in on a dyno at the machine shop, but after I got it home I put it in the frame and ran it a few times a month for just over a year until the car was finally drivable. Neighbors are appreciative if you also install the exhaust system with mufflers...
I had a friend suggest the same thing bear and it really does sound like a good idea. I think I will go that route thanks
You could get the cheaper one you listed and get a radiator and take it to a local vocational school. They should have the metal to mount it and any mods you want. They will do the work, usually for only a small donation.
Larry
