Hello gentlemen. I’ve been lurking for a bit but decided to join as I plan on sticking with the GTO for a while.
So some background....
I previously owned a 2006 GTO. Had ported/polished heads, cam (236/240 with .610 lift on a 111Lsa), intake, fuel injectors, custom made cold air kit (actually registered ambient temps), long tube headers, wheels, drag bags, dash-hawk engine monitor, etc etc.
Made roughly 480-490 at the wheels. Planned on procharging it, but it never work out.
Fast forward 10 years and now I have a 1971 gto convertible. 400CI engine. New rods and pistons but original crank (I believe). Bored over slightly. Heads had valve job and whatever else was needed to run on unleaded, but no port work. Has long tube headers and exhaust. Has what was called a “correction cam” put in. Has a 3 speed auto which has been rebuilt. It has an edelbrock carb, but I have the original Q-jet in perfect working order in a box, ready to be swapped back on.
Car is all original. Runs like a champ. Starts right up, has a nasty looping idle which I love, shifts hard and chirps gears.
As many men before me, I want more. There are changes I want to make for aesthetics, and others for power. I’ve been searching and reading, but figured I should join and just ask.
I need to fix the AC. It’s all original still but doesn’t work, not sure what’s wrong with it. Anybody know a
Power wise, I debated swapping an LS engine in. Sacrilege I know. But I was given pause by a few things...
-If I swap an LS in, do I need to swap the trans? I mean it would make sense to swap trans and have more than 3 gears, but an engine/trans swap is getting pricey.
- the current engine runs great, and already has headers, work done. Do I want to pull it?
- the car is original, not a clone or anything. I don’t want to shit all over the value.
So I’ve been doing some reading and I keep seeing KRE aluminum D-port heads mentioned.
So my questions....
How much power would I pick up with a set of KRE ported (for the street) heads? I’m trying to see if I can justify spending $2500 plus install costs. Are we talking 25hp, 60hp?
Is it worth the cost, or should I drop in a LS or big block (if they bolt up to the t
If I swap heads, would a higher lift cam really be worth it as well? What kind of power over stock are we talking with a head/cam swap over stock? Anybody got say I results with this head swap?
As for the trans.... more than 3 gears would be great. More performance, and the engine wouldn’t be screaming doing 80mph on the highway. But as said, the trans runs flawlessly. Would a gear vendors over drive be a good solution?
Im fairly certain you guys would all agree to put the q-jet back on 😁
Im apologize for the 20 questions. I am not very familiar with the older engines/cars from a technical standpoint. I’ve always loved them, but this isn’t first first-hand experience. I want to come up with a solid game plan and execute it. I don’t intend to keep switching directions and redoing work. So I’m trying to see what my results would look like with the heads or heads and cam and see if that satisfies me, or if I will be left unfulfilled.
last question... any of you guys in south Florida? I need a good shop I can trust down here. I don’t want some
*** “working” on my new baby and half adding it, or learning about Pontiac’s on mine.
Thank you gentlemen for your time. I’ve enjoyed reading through this board for a while and seeing your cars and the work you’ve done.
