cuspid said:
The C5 corvette's don't come with a spare. The coupe and convertible comes with run flat tires. The Z06 comes with a can of fix a flat and a air compressor. How much does the GTO spare cost (wheel and tire)? I tried the spare on the front of my corvette, but not the rear. It works.
If it clears the brakes on the front it should on the rear, too.
However, if the rolling circumference of the spare isn't close to that of the wheel and tire you replace, it might cause some ABS and traction control problems. You can always turn off TC in the Vette, of course. However, in the rear, if the diameter is not correct in the rear, it will cause excessive wear in the limited slip differential.
Sorry, don't know the price. The spare looks cool, though!
