There a ton of GTOs reporting oil consumption over the much bigger LS2GTO board; you can do a search there.
But I can attest myself that if you guys don't have a 'catch can', a lot of that oil is probably being ingested courtesy of the PCV valve.
I installed a catch can (EE), and after a 2K-mile trip to Vegas, the can trapped about 1/2 pint, and this was with very easy driving. When I replenished that oil with new one, the oil level was practically where it was when I changed the oil (negligible oil consumption).
You also need to check your oil at the same spot every time, and after car has been parked for a while. This will ensure consistent readings. But put a catch can of some sort, to leave the PCV-fed oil out of the equation. Later.
JC
