Installing Edelbrock E Force supercharger this spring and want to add 2 gauges to center stack, like SCSS product, what gauges, AFR, boost, oil pressure or Aeroforce scan guage? What info is most important with F/I? Thanks
Wide band and Interceptor are what i use. The interceptor monitors boost so no need for a separate gauge.
Im going to run a wide band and fuel pressure and boost. This way you can diagnose quick and in a hurry. Depends how much boost your running.. i would say fuel pressure is very important. If your fuel pump starts to crap out and you go lean. you can burn your engine up. But a wideband will show that your air to fuel ratio is off also. I like to know exactly what my engine is doing lol
