1 - 14 of 14 Posts
Hey guys
I have a low mileage 67 gto ho that’s pretty much all stock ..original motor ,carb,distributor etc .the car runs strong and fantastic. Brand new battery also . .the starter cranks the motor over strong and fast also . It’s starts first crank very easy when it’s cold ,but when it gets up to operating temperature and I go to start the car it cranks quiet a bit and then finally starts but maybe sounds like it’s kind of loaded up . But when it starts it runs very strong .
Anything I should look at to fix the problem?
My '66 came with a Carter carb, but now has an Edelbrock. I had similar problems. When the car was shutoff, the gas would heat up and boil over into the intake manifold causing a very rich mixture at startup. I removed the carb and found a thin mounting gasket. I ordered a FELPRO 13834 gasket which is 2 layers fastened together, and is around 1/4" thick. That solved my problem.
So a thicker gasket fixed it ...interesting
No it won't ....there are several root causes for hot start problems. Most likely try holding the gas pedal down ~ 1/4 the way when cranking and see if that helps....most likely the fuel has boiled into the intake / car is flooded.
How do fix that problem ?
Well depending on which carb you have, you can buy a reflective shield and phenolic spacers (you'll need to get the longer studs too). I have the tri power setup and there is no readily available heat shield, but I do have phenolic spacers. I am fabricating heat shields to see if they help.
While I have seen an improvement with the phenolic spacers, after driving hard and parking the car I can literally hear the gas boiling in the carbs...
The thicker gasket will help insulate the carb from the hot manifold, which causes the fuel to boil over into the manifold. On some of my big block Mopars I had to install a 1/2" phenolic insulator between the carb and manifold to prevent the fuel boiling problem. I had considered doing the same thing to my GTO, but the thicker gasket solved my problem. I'm just putting it out there for your consideration.
Hey guys
I have a low mileage 67 gto ho that’s pretty much all stock ..original motor ,carb,distributor etc .the car runs strong and fantastic. Brand new battery also . .the starter cranks the motor over strong and fast also . It’s starts first crank very easy when it’s cold ,but when it gets up to operating temperature and I go to start the car it cranks quite a bit and then finally starts but maybe sounds like it’s kind of loaded up . But when it starts it runs very strong .
When I read this - I interpreted as similar to a hot start issue I have.
So to clarify - is the engine cranking rate the same when cold has hot?
If the heat from the engine transfers to the starter wiring and starter motor - this dramatically increases the resistance in the circuit causing slower cranking. On very hot days (~90) and driving for ~25 mins, mine will not crank at all for ~15mins. I have to pop the hood and wait it out.:|
Yes, it sounds like heat soak. When the car is shut off heat reaches the carb 3 ways....
Conductive, Radiant and Convective...
The fix for Conductive heat transfer to carb is a phenolic spacer under the carb...
The fix for radiant heat is radiant heat shields between the carb bowls and the intake
The fix for convective heat is to open the hood or install a fan system of some sort
You can also wrap your fuel lines with DEI Fire sleeve wrap...
First start with a phenolic spacer, it may fix it and get more
If needed...
We are in winter blend gasoline now and it has a very low distillation curve...boils fast
If you have a hood blanket remove it they hold way too much heat
Also, with a '67, there is a one-year-only heat passage in the intake under the carb for quicker warm-up. The factory installed a stainless steel plate under the carb gasket to block raw exhaust from boiling the underside of the carb. Many of these plates have gone missing over the years. Mine was when I got it. The plate is MANDATORY with a '67. I used two base gaskets and installed the plate in between like a sandwich. No more percolation or flooding. And I live where it's HOT. On my '61 Corvette, I had to make Masonite spacer plates to install under both carbs to insulate them from engine heat. It solved 90% of my percolation problems. Today's gas is formulated for fuel injected engines, not carburetors, and boils off very easily.
A little off topic but I wanted to share that I had the same issue. I installed larger battery cables and a Powermaster mini starter and it solved my problem.
I had similar issues with my Buick 350 at one point. I added a carb spacer to keep the carb from getting too hot and boiling out the gas that was in the carb. Additionally I wrapped the fuel lines with an insulator to keep the fuel in the lines from also getting too hot.
Another thing that could help with the issue of vapor lock ( if that is actually what is happening ) would be to add an electronic fuel pump. If your fuel is boiling out of the carb when it sits this means your fuel pump has to pump gas back up to the carb. Adding an electric fuel pump would ensure your carb is getting fuel before you turn the key. Just my .02 Cents
It’s a carburetor. They do that. Hot start procedure from the owners manual probably says to slightly depress the accelerator. Hold it open until the engine clears it’s throat. DON’T pump the pedal.
1 - 14 of 14 Posts
