Just installed eldabroc shorty headers and now car runs rough maf code came up, replaced it still persist replaced plugs and wires still persist any clues?? Also idk if in relation but check oil keeps popping up and going away but oil is just fine btw it's a 2004 gto upgrade are kn air filter and slp cat back exhaust
Those headers shouldn't make a MAF code come up. Fueling may be a little off but it should not affect idle at all unless you have a pretty big exhaust leak. The K&N may have oiled up the MAF sensor. I would start by making sure you don't have any leaks in the intake path and to carefully spray the MAF sensor with a cleaner made for that.
You'd be best to have a mechanical gauge check of your oil pressure. Just because it has the correct level of oil doesn't mean it is being pumped to minimum pressure. It could also be the oil sending unit is going bad and the mechanical gauge check will verify if it is.
