I put the factory heat choke on my 71 400 with the quadrajet the first one I got had a bend in the rod about 1/2 from end another I have (that I put on now is a straight rod, which is correct, also would it be place in the slot toward the fron of the engine or the back slot and also when insterted would the clip side of the rod (where it attaches to carb) be facing out or in toward the carb, as I sit now I went with the straight rod in the slot toward the front with the clip side facing out... it closed the flap all the way when cold this way and I idled a while and it opened but only about a 1/2 inch, so Ill have to see of it opens all the way when at operating temps
