1 - 13 of 13 Posts
A small brace that holds the fender to the frame? I have one on the driver's side but am missing the one on the passenger's side. Can't figure out what it's called, have had no luck with Google.
Discussion Starter #2
I sent a pic to Ames and they said it's not OEM. But there are factory-looking screw holes that this fits into so clearly SOMETHING OEM goes there. Can anyone with a "more OEM" 68/69 GTO take a look and tell me what you see? I can always just get a bracket at Home Depot, cut it to length, and twist it in a vice to match, but I'd really like to know.
Can't really tell from your photo - a good shot, but how about one a little further away to show placement and orientation.
My guess is that with all that undercoating, that is the lower fender brace area found at the back of the fender adjacent to the door? It should have a tab at the bottom of the fender where it gets bolted up to the lower cowl. That is not factory, so it looks like some one improvised to keep the lower fender from flopping in the wind.
It's actually the the corner of the fender (if that's the right term) past the wheel, not before the wheel. Without it that piece is kind of floppy.
OK, checked my book. Looks to be what is called the Valence Panel to Bumper Bar Support. Check this page out, it is Number 88 in the exploded diagram, page 88 and description is page 89. https://books.google.com/books?id=MGzXnpw2xwoC&pg=PA89&lpg=PA89&dq=1968+Pontiac+GTO,+valence+panel+to+bumper+bar+support&source=bl&ots=fy8Nl09wCB&sig=K7H4SzWwBJw5zIpNIgX8XUCQ4sM&hl=en&sa=X&ved=2ahUKEwio5fTktK3fAhVrTd8KHYynDKsQ6AEwFnoECAgQAQ#v=onepage&q=1968 Pontiac GTO, valence panel to bumper bar support&f=false
Now that I'm under the car I think I made this bracket during the resto, I believe I ordered the above brackets and they didn't fit in any rational manner. The one in your pic above is definitely home made as well. I'll attach a pic of mine and I'll do some research tomorrow as I'm doing work on the car again and may redo some of my previous work. Maybe someone else will chime in with the original setup... Cheers
Since I could find no pics of these fender to core support brackets during my resto I snapped one. I got these on eBay, blasted and sprayed them, they fit nicely.
1 - 13 of 13 Posts
