I just bought a 64 Le Mans to cut my teeth on. It has a 327 in it, with a 4 speed Muncie. The rear end is an 8.2 B.O.P with a 2.78 ratio. Yes, it is dead off the line and I want to re gear it but the more I read, the more confused I get. Im pretty sure I should go with a 3.23 but can't figure out if I can with my carrier. I dont want to buy both ring and pinion and also a new carrier. Can anyone tell my for sure, how low(in power) or high(numerically) I can go with my gear ratio by just replacing the ring and pinion. Can someone suggest a knowledgeable company that i can call, tell them what I have, and they can tell me what fits.im new to this game, so any help is much appreciated.
You didn't mention if it is a posi, not that that matters on a gear change; however, it may just be more cost effective to swap out the entire rear end assembly. Where are you located?
As far north as you can go in new york state without being Canadian. There is a P stamped on ring gear but its an open differential. Spin one wheel the other goes backward
