well i just found out the motor i got with my gto "400ci" runs on alcohol... wow i know right. can i convert it back to pump gas?? or would i be better off getting a LSX motor.
You should be able to convert it back to gas, possibly a new carberator (all jets are bored out for alcohol), retard the timing and check the engines compression ratio, alcohol requires a higher CR between 12:1 to 15:1.muthstryker said:well i just found out the motor i got with my gto "400ci" runs on alcohol... wow i know right. can i convert it back to pump gas?? or would i be better off getting a LSX motor.
