do you have an engine for it that's about I could help with
ah, the johnny cash method.Like eating an elephant. One small piece at a time. Do one small thing each day. Don't let it consume you.
You already asked for help, and now you are telling us what your car needs one step at a time.. . . I don’t like asking for help. I'm trying to finish this . . .
I am in south central KY and probably come and help on a weekend or 2 or anytime you are off if not retired ! I do mechanic work and auto body. Could wet sand and buff your paint for ya. Let me know if you can't find anybody closer. If you can't I don't care to help ya !Live close to Ruble rd and Hogan. Northeast corner of Dearborn County. Painted but needs wet sanding and buffing. Installed new headliner , myself , due to body shop spraying compound thru open windows. Installed new dash with wood grain. All new wiring harnesses. Engine turns over but needs timing and basically looked over. Needs distributor set “ top dead center ? “. I’m overwhelmed. I’m dyslexic. So “ here read this “ is not a great answer for me. I can installed and do anything. If I’m shown Or pictures. I’m on the cliff. Not fun anymore. Got screwed and I’m trying finished. I need help getting it completed. I’m so close. But I have no help. I did Auto glass for years. At cars shows. Installing glass in classics. But I’m lost when it comes to engines and electrical. This is the most I’ve wrote ever.
Google maps say 201 miles....3hr 10 min drive ! Not to bad I guess for a fellow gto fan.
Thanks. Spark plug wires are on the wrong plugs. He put the shorts one in front and long in back. That’s what I’m dealing with. I have to back over everything he did or should I say didn’t do Right It’s morning. So it’s a new day. Trying to get started.You already asked for help, and now you are telling us what your car needs one step at a time.
First, set up your area around the car with a small bench, your tools, and a storage area. That is your work area. Next you will find top dead center TDC. Keep the battery connected but remove and mark the small wires to the coil.
Disconnect the spark plug wires at the spark plugs and mark them so they don't get mixed up. You can confirm later if they are correct. Then remove the spark plugs and poke them into a piece of cardboard so they don't get mixed up. Keep your area clean and let others know that is where you are working on the car.
Check in when done, or if you have questions.
Great advice, but it doesn’t help. I am stuck. I don’t know engines and I don’t know wiring. to I’ll just push it outside and let it rot You Know. I don’t like asking for help. Im trying to finish this so my Father can see the car he always wanted. He gave it up dream when he had kids. Always showed me pictures I even have a Matchbox ‘68. . Never mind.
I've hit the frustration wall a few times over the years. A new day makes things look way better.Thanks. Spark plug wires are on the wrong plugs. He put the shorts one in front and long in back. That’s what I’m dealing with. I have to back over everything he did or should I say didn’t do Right It’s morning. So it’s a new day. Trying to get started.
