. I’m retired also Probably should have done this a couple of weeks ago
. I’m retired also Probably should have done this a couple of weeks agoGoogle maps say 201 miles....3hr 10 min drive ! Not to bad I guess for a fellow gto fan.
If you can do a headliner you can get a motor running 👍https://butlerperformance.com/p-34888-pontiac-engine-torque-specs.htmlHad originally #16 Heads installed. But I’m doubtful the ROCKERS are set right. And would taking the valve covers off , help find TDC? Have to replace the valve covers bolts ,because he stripped them. Is there a torque setting for the ROCKERS lock nuts ?
Depends if it has the stock style rocker studs or if they were replaced to make the valve train adjustable. Was this a project that your dad started and never finished? If so, does he remember details about the build or do you know which shop he used? No reason to remove the covers to find TDC if your damper is marked correctly. Remove spark plug #1 and turn the engine over by hand. You'll know you are c lose to TDC when air starts coming out of the hole where the plug goes.Had originally #16 Heads installed. But I’m doubtful the ROCKERS are set right. And would taking the valve covers off , help find TDC? Have to replace the valve covers bolts ,because he stripped them. Is there a torque setting for the ROCKERS lock nuts ?
Well let me know if you need me to come up, as it is not to far away. Be glad to help if you need me to.. I’m retired also Probably should have done this a couple of weeks ago
VERY GRATEFUL. I’ll probably take you up on that. Let me see how it goes.Well let me know if you need me to come up, as it is not to far away. Be glad to help if you need me to.
Nice, and I forgot my disclaimer of not being the smartest one on here which Amy will testify so there might be better advice from the experts....just a CYA for me in case something goes wrong 😉Rockers set to 20 lbs. found TDC. Working on Distributor
Do you have spark and fuel delivery, have you ever had it running and how old is the fuel????Rockers set to 20 lbs. found TDC. Working on Distributor
Not to confuse you but number one can really be anywhere as long as the rotor is pointing to where the #1 plug wire is connected.New fuel New tank. New pump. Has spark. Working on getting Distributor. Have top center. Trying to get the distributor to point at #1
