Can anyone recommend a paint that they have used, that has held up on high heat areas?
I am referring to the block, heads, and intake.
I am looking for a High heat paint preferably in spray cans.
thanks,
Tim
I used Eastwoods ceramic engine paint. Big mistake many make is to pile on the paint on the manifolds and intake exhaust ports. Mine included My paint turned a goldish color and wore off to the cast color and it blends in.
Secret I am told is to lightly apply the paint to those areas. If you drive your car like I do the paint will burn off.
When I purchased my car I scraped loose paint off and cleaned well with brake cleaner masked and rattle canned the engine with dupicolor's correct medium blue: 500 degree paint. It held up pretty good over top the old paint.
your head exhaust runners will discolor if you like to drive it, our motors are too MEAN for paint.... Really think it is the metallic color as you would not notice if they were carousel red (hugger orange to a chevy guy).
The hot tip seems to be to paint the exhaust port area with a super high heat silver stove paint, and then mist the engine color over it. This will last about 500 miles or so. Me, I never bothered. Just Krylon in a can, and it burns off int he first 500 miles or so anyway....and the rest of the engine looks great for years and years. Burnt paint on the exhaust ports is like rubber powder in the rear wheel wells ...it's a sign that you actually DRIVE your Pontiac!!
:agree That nice golden brown color on the exhaust ports is a direct result of all the little paint molecules being frightened out of their wits due to being forced to live so close to the T-rex of Torque with the predictable result of them dropping tiny little paint-loads in their tiny little paint-pants.
Mates,
I have a 1967 GTO that is nearing completion (I hope) of the metal work (both quarters had some rust and both hinge pillars). I am anticipating dustless blasting next spring. Is the next step then application of a primer or filler? I assume there won't be any new areas to do metal...
I need to touch up my 389 in my '65 GTO and have had no luck matching the color.
I have #208 Pontiac blue from Valspar and DE 1616 Duplicolor which both have a silver
like color that I see in the later model motors.
Can anyone steer me to the non metallic old school blue green color I can...
Looking to add the Judge stripes (only) to my '69 GTO (Not the Judge decals). Where can I find placement information? I got hold of an actual drawing from GM, but the file format looked like an old 30th generation Xerox copy so none of the dimensions were clear enough to read.
Do they make a upper dash panel for a 1966, GTO, LEMANS? I looked all over the inter net for one and could not find one. I would think other people had this same problem, lower part of the dash/ windshield needing repair?
