Somewhere I read that there is a brake sensor that prevents RPM increases when pressing down the accelerator and holding down the brake. Can someone help me. Where is the brake sensor and how do I disengage it. Thanks.
This is a problem with the 06 A4s. The torque management will not let you brake torque the car for a burnout. There is a lot written about this on LS1GTO. Do a search on brake torque and you'll find a cure!Paul1stSGT said:Somewhere I read that there is a brake sensor that prevents RPM increases when pressing down the accelerator and holding down the brake. Can someone help me. Where is the brake sensor and how do I disengage it. Thanks.
I thought they were called either traction bars or anti-hop bars?86Noel said:I need traction brackets for my car
Thanks, that's probably where I read about the brake sensor. I'll go check it out.hishep said:This is a problem with the 06 A4s. The torque management will not let you brake torque the car for a burnout. There is a lot written about this on LS1GTO. Do a search on brake torque and you'll find a cure!![]()
