It's best to remove the Bezel from the housing and do this on the bench.
Once off if you look under the chrome trims pieces you should see the tabs/tangs that grab the metal.
These strips are slipped over the top portion first then pressed/pushed onto the bezel, so removal is in reverse.
Using a good plastic trim removal blade tool you have to gently pry the underside/bottom edge of the trim and lift out/upward so the top can lift off the bezel.
If your not saving the ones on the bezel then no worries,
the first one will be the sacrificial learning tool ;-)
133127
133128
133130
