I would recomend buying a new hinge ...
if your roller is bad or the pin worn so is your hinge metal
also
the notched area the roller rides on losses its point,,,
then the door doesnt like to stay open
and youlle end up buying a hinge anyways
paint it install it and an hour later your done
Thanks , Judge,
Well my doors stay open and they shut and are nicely aligned. SO, can't I replace roller and pin separately and does the door have to be removed to do this?
This is a fairly easy job bud if your mechanically inclined at all. Just order the kit, Ames or OPG should carry it, comes with a pin and 2 bushings. The hinge should be fine unless it has been loose for a long time and it ate the bushing. You said the door closes fine so I’d say your in good shape. Just make sure you support the door real good before you tap the pin out
