Please don't forget the AMSOIL SDF filters which consistently outperform all of these in indepent testing:
AMSOIL SDF Oil Filter
In answer to the original posters question, Mobil 1 synthetic is a good oil that will last until your oil life monitor suggests to replace it. Also note that the owners manual will specify an oil change at least annually independent of what the oil life monitor says. I would not run any oil past the limit to which the oil life monitor suggests unless that oil had its own warranty because you are outside the limits of the manufacturers warranty requirements if you exceed the oil life monitor change recommendation. Mobil 1 does not specify warranty coverage for such use. AMSOIL does however.
AMSOIL makes three tiers of oils to match the longer oil change intervals the auto industry is going to.
AMSOIL XL Motor Oils are designed for 7500 miles/6 month oil changes or longer when using an oil life monitor (e.g. they can be used up to one year or when the oil life monitor requires an oil change).
AMSOIL SAE Synthetic Motor Oils are designed for 25,000 miles/12 month oil change intervals.
AMSOIL Series 2000 Motor Oils are designed for up to 35,000 miles/12 month oil change intervals.
:cheers
