1966 LeMans manual steering. I need to remove the steering shaft between the gearbox and firewall. I loosened the clamp on the shaft where the column comes through the firewall and a dozen or so ball bearings fell out so apparently I need to replace the bearing at the end of the column as well. I referenced my chassis shop manual but it’s no help and even the exploded view of the column leaves a lot to be desired. Part of my being stumped is not understanding how this shaft is connected (I’m assuming) to another shaft in the column.
Can anyone tell me how to remove the under hood shaft without removing the complete column? Also what is the name of the bearing that came apart so I can order a replacement?
This picture shows the clamp I loosened and slid down the shaft. The bearing race is sitting on top of it. You can actually see a few bearings that fell out on top of the frame below.
TIA for any assistance.
