It would be awesome if someone could give me a guide to change brake pads myself. i heard it is rather easy and i was hoping i could do it myself and save some many. would be a huge help!!
It's so easy. . . even a cave man could do it.:D It's been covered many times in many places. Once you do one wheel you'll go "duh". You need a large C clamp or even better yet get a Harbor Freight disc brake kit. You use either to push the caliper pistons back in so you can get the "thicker than used" new pads over the rotors. That, a couple of wrenches and a jack stand
How To Change Your Brake Pads - Edmunds.com
So I am in the same boat here finally changing out the brakes. I have an 05. I read that I need to replace the "torque to yield bolts" that hold the calipers in place with new bolts & washers. Is this something that really needs to be replaced every time you remove the calipers or is this just a revenue generating thing?
I am going with DBA 4000 t3 slotted rotors with Hawk HP ceramic pads if that makes a difference.
I've changed out hundreds of pads and never replaced those bolts on any car I've owned or worked on and haven't had any problems in almost 30 years of changing pads.
X2. I've never replaced those bolts either.
I do have an OCD issue of cleaning each bolt off with a wire brush and also use a dab of locktite.
Thanks for your help, time to go to work. I thought it was a little over the top to be replacing them but just wanted to double check.
