1 - 12 of 12 Posts
I'm thinking about buying a 72 "GTO"... The guy says it had an engine swap & hes not sure if its a original GTO option Lamans. The decoder sites didn't help much. How can I tell if its a true GTO option? Thanks for the insight. :cheers
67 Basket Case Restorer
The fifth digit in the VIN is an engine code. GTO's only came with a 400 or 455. The code for 400 is T, 455 is Y and 455 HO is X. If the fifth digit is anything other than these 3, it's not a GTO.
Got to get the PHS as the GTO was just a option on the LeMans coupe or Hardtop. Total production for 1972 GTO's was just 5,807. Hope you find out it's a MT w455 H.O. only 3 were make as a coupe and only 310 as a hardtop. I always like to call the coupe a post.I think it is better terminology. GOOD LUCK LES
Here's a list of all the vin codes for a '72.... Just additional info....
1st digit - Division -
2 = Pontiac
2nd digit - Series:
D = LeMans
G = Luxury LeMans
3rd and 4th digits - Body Style:
27 = 2-door sedan (post)
36 = 4-door wagon, 2 seat
37 = 2-door coupe
39 = 4-door coupe
46 = 4-door wagon, 3 seat
67 = 2-door convertible
69 = 4-door sedan
5th digit - Engine Code:
D = 250 1-bbl L6 110 hp
M = 350 2-bbl V8 160 hp
N = 350 2-bbl V8 160 hp (dual exh.)
R = 400 2-bbl V8 180 hp
S = 400 4-bbl V8 200 hp (single exh.)
T = 400 4-bbl V8 250 hp (dual exh.)
Y = 455 4-bbl V8 250 hp (dual exh.)
X = 455 4-bbl V8 300 hp (455 HO)
6th digit - Model Year:
2 = 1972
7th digit - Assembly plant -
A = Atlanta, GA
C = Southgate, CA
D = Doraville, GA
G = Framingham, MA
L = Van Nuys, CA
N = Norwood, OH
P = Pontiac, MI
R = Arlington , TX
W = Willow Run, MI
X = Kansas City, KS
Z = Fremont, CA
2 = St. Therese, Quebec, Canada
Last 6 digits - Production sequence starting at 100001 at all plants.
thanks guys
Ok cool, thanks for all the info. I hope its a true GTO. If not you guys think I should still get it? Basic stats are: It needs all the typical restoration... from brakes, to the motor, to interior work, & body, but its not a complete "rust bucket". It seems like a good deal at $3k.
Call PHS and ask for the docs to be faxed. 3k is only a good deal if you can do the majority of the work and you have less in it when done than it's value. A true GTO will have a considerably higher value. A clone will turn you upside down in a hurry.
Check the frame for rust damage too. If the body is rough the frame may not be much better.
Where is it? I'll come git it, nothing is too rough for me. There were quite a few T41 optioned cars in 72 and a T, Y, or X doesnt mean it is a GTO, but it would still be a cool car. You want to build it and enjoy it or flip it for profit?
Thanks again guys. Thumpin455 I just got a 68 Firebird that I'm fixing up for my self so I was thinking of maybe getting the "GTO" to clean up, get running, & flip.
1 - 12 of 12 Posts
