Ut-oh! You just opened up a can of worms. Some will strongly agree with keeping points, some will strongly agree that electronic is the way to go.
Personal experience - points will do the job, or electronic. I do not like the factory HEI.
I did the Pertronix conversion, I think it is now called the Pertronix I, as there was no other options at the time. I bought a remanufactured points distributor, I think from Advance Auto, that was remanufactured by Cardone. This gave me a good base to work with as 40-50 year old distributors can be worn/sloppy. Never had a problem with it, but you will read/hear that others did have issues - but this was also when it first came out years ago. It was a simple conversion and I followed the directions. The conversion, like most all electronic set-up, require a 12 volt power wire to the coil versus the use of the resistor wire used on a points distributor. Not using the 12V is where I believe many of the problems were related to.
On my current/future 455 build, I purchased a new Pertronix II distributor and their recommended/matching coil. There are other makes out there that probably work as well, just my choice on this one.
I feel that an electronic conversion/distributor is the route to go. You don't have to change out points/condensors, set dwell, or worry about point bounce or rubbing block wear. Aftermarket points/condensors can be junk, so many opt for NOS Delco points/condensors from Ebay. With the low mileage most run each year, points will last a couple seasons before needing to be replaced. if you can't do this yourself and have to go to a shop, you may have to hunt around to find someone who knows how to do points anymore.
I like the MSD box as it provides a multi-spark at low RPM's which can help idle quality and a better fuel burn. I got the 6AL which has the rev limiter. It provides a "hotter" spark. Have used the earlier MSD6 in 1982 with good results, so going with another on my build.
