RIP (12/27/60-7/18/15)
why are there 2 seperate connections on my intake manif for pcv?
thanks as always
The other one is for accesories, or not used and plugged. Did you look at that GM starter shim kit that inlinetube sells for $8.00? It's a great kit.
Freethinker is correct. Your PCV line goes to both fittings. There is a special nylon "Tee" that is unique to your car. The vendors have them ...it's not cheap for what it is. The '67 has a "dual plane" intake and you get PCV vacuum from both ports.
