the plate numbers are 65 23737 body bf287 trim 215-24 acc 1113
body by fisher
9A Pontiac, Michigan 5
is this a gto or lemans gto??
Your car is a Fremont, Ca built 1965 Lemans 2 door hardtop coupe with Gold interior built on the 1st week of September.
The GTO in 1965 was an option on the Lemans series. The only way you will know if your car is a true GTO is to get a PHS (Pontiac Historical Society) paper work search. PHS has a website to request your search.
It is a Lemans. In 1965 the Pontiac plant was one of only two plants that designated the GTO with the code of 5N on the data plate on the firewall. As stated before, PHS will give you all your answers.
The 5N (code for GTO) was used in the Pontiac plant (PON) and the Kansas plant (KAN). The cowl tag in question though is from Fremont, CA (BF).
:agree
Also, Fremont was the only plant that used The UPC coding system the OP listed above, The car was an early production built the first week of September 1964 and was the 287th Tempest, Lemans or GTO built in Fremont.
