Just ordered a 2006 GTO and just wondering with like a couple grand what would be a nice setup for the car as in exhausts, superchargers, etc. Also anyone know of anything to do these services(posted beneath) because i saw on SLPonline.com that they are offering these services for only 04-05 idk if its out for 06 yet or would it be same.
* Recalibrate speedometer for non-stock gear ratios*
* Remove top-speed limiter*
* Disable Computer-Aided Gear Selection (CAGS)**
* Disable torque reduction**
* Disable shift delays**
* Increase shift firmness**
* Raise rev limiter**
* Raise WOT shift points**
* Adjust cooling-fan activation points**
* Adjust AC shut-off for WOT**
* Disable vehicle anti-theft system**
* Disable catalytic-converter over-temp feature**
* Disable EGR**
* Disable air pump**
* Disable specific error codes**
* Install SLP High-Performance Spark Advance***
The link is this if you would like to check this out yourself http://www.slponline.com/view_product.asp?P=PCM1
* Disable EGR**
