1 - 20 of 22 Posts
I am looking for a bit more power out of my 400 ci motor. I am running low compression (#14 ? IIRC) heads and have been considering upgrading to KRE aluminum heads and a new camshaft. A friend is suggesting just adding a flat tappet camshaft and waiting until I build the motor and go all out. Thoughts?
Depends on how much money you have to spend on your car.
I you have plenty, buy the heads & cam now, then worry about the future build when that time comes.
If you don't have a big budget, you might consider buying the alum heads ONLY if they are also the heads you'll use on the new future build.
You can always sell the alum heads. BUT, most of the time you won't get more than half your money back. Pontiac guys who can't afford new alum heads, usually can't afford more than half price for used heads.
Most HFT cam set-ups don't cost that much, unless you buy Crower cam & springs. If you can settle for a Summit 2802 cam & Jegs lifters, you can save a few bucks. That's what I did for my super low budget 455 bracket project.
Obviously, the guys here will need all the engine & car specs, as well as your power goals, in order to make a specific cam recommendation.
Famous quote from A.J. Foyt: "Speed costs money. How fast do you want to go?"
It's no secret that building a Pontiac is very often more expensive than building a bowtie -- owing to parts availability, parts cost, and difficulty in finding people who actually know what they're doing. Balancing the money side of things is the hardest part and there are tradeoffs always. For example: building a flat tappet engine is a crap shoot these days because it's now literally been decades since any "new" cars had flat tappet valve trains, so the quality of parts, especially the "affordable" ones has declined. You can do everything right including using high zinc content oil (if you can find it) and still just be unlucky and wipe out a lobe, causing you to have to start over. The obvious answer is to go with a roller system, but those are more expensive in terms of parts cost and also indirect cost (different valve springs, different installed heights that require machining the spring seats in the heads, different pushrod lengths, etc.) -- and they too come with their own dangers. If a roller bearing or bushing goes a way or a link bar fails and allows the lifter to turn sideways... the results ain't pretty.
Building an "all out" Pontiac and doing it right with the best quality parts can easily cost you north of $10k. I"m not trying to discourage you from doing that, in fact quite the opposite --- however it's sad when someone starts down that road without realizing what they're getting into and then have to stop without ever getting it finished because it got too expensive. The result is another permanently dead Pontiac - and no one here wants that.
So, back to your question: First be honest with yourself about just how far you want to take it and realistically how much you're able to fund the project to get it there. Details like gear ratio, transmission type, rear axle type, how you plan to use the car (street machine, race car, highway cruiser, etc.) all influence your other choices. An all out race engine that doesn't even begin to make significant power until it's north of 4000 rpm is going to be a miserable experience in a car that spends most of the time cruising the streets down to the local hangout, and it's also not going to be very successful in "stop light wars" - or anywhere else except the drap strip.
Ok --- heads. Just about any of the popular aluminum aftermarket heads are going to outperform all of the Pontiac factory heads, except MAYBE the rare as unicorns Ram Air V's. I personally have a set of ported Ram Air IV #722's that I had flow tested, and even those don't flow as well as my Edebrocks that have been treated to a basic entry level street porting. The tip on aftermarket heads is to buy them bare - i.e. without valves or springs. There's a reason that the price difference between bare heads and so called "ready to run" heads isn't that much. Check out the videos:
No, buy the heads bare and have them sent to an expert "head guy" to have them outfitted with high quality valves, springs (to match the cam you've selected), retainers, locks, etc. If you can afford it, spend a little extra to have him work the ports a little.
Camshaft: The most significant criterion for selection is expected RPM range. Where is the engine going to live most of the time? Pontiacs aren't chevys so we don't have to fret so much about killing bottom end torque, but still you can't ignore that completely. An engine that has a torque peak well within the RPM range where it spends most of its time is going to be the most fun to drive. Don't go chasing horsepower to the exclusion of all else. Remember HP is really just a mathematical formula: HP = (torque X RPM) / 5252. (That's why on every honest dyno sheet the torque and HP plots will *always* cross at exactly 5252 RPM). Take an engine that makes say 450 lb ft at 2500 rpm vs an engine that makes the same 450 lb ft but at 5000 rpm ---- the second engine is making TWICE as much horsepower (because of the formula) even thought it's not pulling one ounce harder. Furthermore, on the street and everywhere else except maybe the drag strip, that first engine is going to eat it alive (because at normal street rpm, engine #2 is going to be a dog). Pick a cam that's going to put the torque peak in a reasonable spot, then work "outward" from there.
Compression: You can get away with more with aluminum because the material doesn't retain heat as well as iron, and heat is one of the main contributors to detonation. In fact, because of this you really NEED to up compression when you swap to aluminum. This is an area where you'll find passionate opinions all over the map about how much is acceptable, "dynamic" vs. "static" compression, ad-inifinitum. I have my opinions too. However consider this: On a very healthy Pontiac 461 with good aluminum heads and a moderately aggressive (for the street) solid roller valve train, raising the compression from 10.5:1 a full "number" to 11.5:1 makes very little difference. How little? About +15 in both torque and HP -- in an engine that was already making north of 560 in both torque and HP. Taking it from a safe on 93 octane (for aluminum) 10.5:1 to a risky for detonation 11.5:1 was good for about a 2% increase, and that's ASSUMING that you can keep it out of detonation at 11.5:1. Worth the risk? Your choice, but personally, not for me, not on the street... not unless I'm trying to milk every last bit out of an engine for race purposes - but in that case I'd be building it to run on race gas anyway. For iron heads, knock off "a number" - on 93 octane pump gas personally I wouldn't push above 9.3:1-9.5:1 tops.
My .02 - your mileage may vary - void where prohibited by law - slippery when wet - past performance is not an indication of future return.
If you’re spending the money on that setup then spend the extra, get a hydraulic roller cam and a set of link bar roller lifters. You can buy the heads fully assembled and get hydraulic roller springs for roughly the same price. The real question is do you want to spend all that money on updated heads and have 40+ year old cam technology?
40+ year old technology still works! https://www.gtoforum.com/f170/flat-tappet-vs-roller-bs-135559/
Wow guys thanks so much for the feedback, guidance, and help!
The question re the cam vs. cam + heads was really based upon the fact that I know at some point I will build the bottom end (currently a 400 and it will become a forged 455 - 461). No idea when I will build the bottom end as it appears to be working just fine for now (no smoking or bearing noises). From my experience the heads and cam selection make all the power, so I thought about slapping the beautiful KRE aluminum ported heads + roller cam on and calling it a day. I am not sure if doing this will cause issues with the bottom end. That said, I would hate to install expensive heads and then have an engine failure and do damage to the heads.....
My plan was to run 10.5:1 with the aluminum heads. And I guess now I will spend the extra money and just get the roller cam. I was hoping to get some feedback on KRE. From what I have read they seem to really be the benchmark in the Pontiac world, but I was hoping to hear from others that have used their heads.
Specifications on the car:
(1) 400 ci
(2) Muncie 4 speed
(3) 3.55 rear, but I will be swapping this for either a 12 bolt or a Ford 9" with a limited slip differential (probably keep the ratio close to 3.55)
Specifications on me:
(1) old road racer
In terms of goals, I really would like to be north of 400+ ft lbs of torque and 400+ whp (measured at the wheels) or put otherwise a 12 second 1/4 mile car. Redline is ~5000 rpm (ok maybe 5500) and with 400 ci and 3.55 rear, I really think the optimal rpm range to tweak / maximize is ~2500 - 5000, otherwise putting the power to the ground will become an exercise / impossible.
Never said it doesnt work. Fact of the matter is flat tappet is old tech and there are much better options out there if your wallet is deep enough ?
FWIW, stock GTO 400's make about 430-440 foot pounds of torque bone stock. 389's, same deal. With the right tune, very basic, very stock engines can be made to perform quite respectively for not a large amount of coin. It's all in the details.
"...400+ whp (measured at the wheels) or put otherwise a 12 second 1/4 mile car. Redline is ~5000 rpm (ok maybe 5500) and with 400 ci and 3.55 rear..."
Don't need 400hp, at the rear wheels, to run 12.90's.
BUT, the rear tires will have to hook up to the track. Got my '69 RA3 GTO into the 12's. But I had 4.56 gears & 9" slicks.
Now, with a 455/TH400/3.73 gears, it was no problem at all running 12's, in that same GTO. The long stroke torque makes all the difference. I ran 13" slicks to keep it hooked up on slippery tracks.
Now a 400 with alum heads & HR cam that will make good power to say about 5800rpm, might run 12's, with 3.55's & a good clutch. Still needs to hook up. Hard to run 12's if the rear tires spin a lot. With sticky tires, you'll need a stronger rear end. I used 12-bolts. I think 9" Fords are cheaper now.
"...KRE...seem to really be the benchmark in the Pontiac world..."
If this car will be driven a lot on the street, you might wanna consider some Edelbrock D-port heads. They are the only alum heads that have the exhaust heat riser, that will heat the exhaust crossover of the intake manifold. This will be helpful, especially in cold weather.
https://butlerperformance.com/i-24452924-butler-performance-edelbrock-custom-72cc-290cfm-aluminum-d-port-pontiac-cylinder-headspairbpi-72cc-edl-dport-290.html?ref=category:1287735
Here's an example of an alum head 400 that should run 12's, even with a HFT cam.
http://lenwilliamsautomachine.com/400_Edelbrock_Heads.html
Put some alum heads on this stroker shortblock, and you've got well over 400hp/500 torque. Main problems would be traction & driveline breakage.
http://lenwilliamsautomachine.com/455_Short_Block.html
Upgrades would be forged crank & H-beam rods. Pretty easy to get near 500hp, with the right cam.
Butler sells ready-to-assemble shortblocks, for a fairly reasonable price.
https://butlerperformance.com/i-24452991-butler-performance-custom-short-block-kit-400-block-434-494-cu-in-unassembled.html?ref=category:1234783
(1) 400 ci
(2) Muncie 4 speed
(1) old road racer
If you have the deep pockets, then go all out, go big. Here is one of our forum members build with the parts used and dyno results.
I just dyno’d my engine today. It’s a 490 CI stroker, 10:1 compression, KRE D-port heads out of the box, edelbrock performer intake with a mild hydraulic Roller cam, 850 vac secondary carb MSD Billet distributor, and Ram air exhaust manifolds. It made 616 HP and 703 ft/lb of torque on pump gas. I was very happy. I was hoping for 550 HP so this was great. The monster torque numbers were really a bonus. This will def make driving my big heavy 70 GTO a lot of fun! Thanks for all the help you guys have provided me over the last year while I assembled this motor, my first build.
Here's the info on the build:
Ohio Crank forged 4.50/3.00
KB Pistons 943-30 4.5 stroke
Eagle Rods 6.700
KRE Heads 85 cc stock heads
MSD Dist. 8528
RPM Performer intake
Comp cam 235/241HR14+4
Trend pushrods 8.800
Peek HP was at 5,400 RPM, peek torque was at 3,600. One question I had was about the oil pressure. It was recorded by the Dyno throughout the run. It started at 60 psi at 3,500 RPM (the lowest RPM the Dyno recorded data) on one run it went down to 42 psi and on the other it went dwin to 32 psi at 5,800 rpm. Is this a reasonable pressure for a Pontiac engine? This is my first Pontiac build. Thanks for your input. (Turned out the oil was low, filled up, and oil pressure came back)
Mike
An engine with 700 torque will break most every stock '70 GTO part behind it, if you get good traction.
I broke several trans, & a couple of 10-bolt rear ends behind my 455's that had only about 500 torque.
Discussion Starter #12
I live in SoCal and the coldest I see is ~60 degrees (frigid), so the heated crossover is not needed....Your point about the launch is spot on. I currently have pretty wide tires out back and think I can cut a good 60'. I'll be logging some runs using Dragy (which is a great device if you haven't seen it). Dragy is super accurate and has helped me with other projects. Thanks again for your help!
Since you are building the car to drag race, you need to start with the basics and go from there. Cam, heads, intake, timing curve, upgraded rear end with steeper gears, traction bars/adjustable 4 link, ball joint spacers up front, sway bars removed, etc. etc. Big difference in 'wanting a little more power' from your engine and what you want to do, which is race the car. Lots more $$$$, too. LOTS more.
Discussion Starter #14
No I am not looking to drag race, just a 1/4 is a good means of testing the power....I just did my first 0-60 timed run in the GTO and it was funny - 0-60 mph 7.6 seconds....
I had my 400 built in Tennessee when I first bought the car. I bought Edelbrock heads, aluminum intake, Holley 4bbl and Dougs Headers from Butler, had the block checked and line bored, all new rotating assembly, and a custom ground roller cam. On the dyno at Butler it puts out 470 lb ft at 3900 rpm and 445 hp at 5500. But it ain't cheap. Expect to spend at least $10,000 if you have it done. Obviously less if you build it yourself. I'm still in the breakin period, but it's got plenty of power for a street car.
Discussion Starter #16
OK, reading other posts and trying to make sense of all the data and recommendations, including the cam you designed Jim, I am still a bit confused on the path to take.....
For me, and most of you I'd guess, performance tuning is just a fun hobby with lots of ideas and thoughts on how to make the car more fun and faster along the way. The honest answer is I really have no idea how much horsepower I want or need in the GTO, but a little faster than it is now would be nice. Does it need to snap driveshafts? - no. I also want to keep costs under control and don't want to drop $10K into a motor (at this time). Ideally I could take an iterative approach and see the gains each step of the way. As long as I am staying with iron heads, I am fine with a HFT cam. Would an 068 cam work well in a 400 with #16 heads (running 91 octane + Torco accelerator)? How about with the #14 heads (lower compression)? My thought being, just install a HFT cam and lifters with the #14 heads; if still unhappy install the #16 heads (as is); if still unhappy build the bottom end and buy KRE aluminum heads, roller cam, and call it a day...
For me, and most of you I'd guess, performance tuning is just a fun hobby with lots of ideas and thoughts on how to make the car more fun and faster along the way. The honest answer is I really have no idea how much horsepower I want or need in the GTO, but a little faster than it is now would be nice. Does it need to snap driveshafts? - no. I also want to keep costs under control and don't want to drop $10K into a motor (at this time). Ideally I could take an iterative approach and see the gains each step of the way. As long as I am staying with iron heads, I am fine with a HFT cam. Would an 068 cam work well in a 400 with [URL=https://www.gtoforum.com/usertag.php?do=list&action=hash&hash=16]#16 [/URL] heads (running 91 octane + Torco accelerator)? How about with the [URL=https://www.gtoforum.com/usertag.php?do=list&action=hash&hash=14]#14 [/URL] heads (lower compression)? My thought being, just install a HFT cam and lifters with the [URL=https://www.gtoforum.com/usertag.php?do=list&action=hash&hash=14]#14 [/URL] heads; if still unhappy install the [URL=https://www.gtoforum.com/usertag.php?do=list&action=hash&hash=16]#16 [/URL] heads (as is); if still unhappy build the bottom end and buy KRE aluminum heads, roller cam, and call it a day...
Well, the bottom line here seems to be your indecision to make a commitment to what you want to use. We can't answer that question. Can you work with the #14 heads, sure. Can you go with the #16 heads, sure. Can you go with KRE and roller cam, sure.
If you go with the #14 heads, you may be happy or unhappy.
If you go with the #16 heads, you may be happy or unhappy.
If you go with the KRE heads & roller cam, you may be happy or unhappy.
There is no magic bullet that guarantees you anything - even the cam specs I generated from the Dyno2000 program. The #14 heads and cam might not be enough performance for you, but you should be able to run pump gas. The KRE and roller cam may be too much on performance and may run on pump gas. The #16 heads will mean blending gas for higher octane - which you seem comfortable doing.
Go with #16 heads & "068" cam. A proven combo, right from the factory, and then mix your gas formula for the high compression octane needs. If that does not work for you, THEN go for the KRE/roller cam upgrade/rebuild. :thumbsup:
Without reading back thru the whole thread, if I went with the #16 heads, I'd go with more duration than the 068, such as a Melling SPC-3, or a Summit 2802.
The 2802 has more lift, so should make more power. But a 2802 with stronger springs will probably pull out a press-in stud, if you should try it with #14 press-in stud heads.
The Crane 283951 is similar but costs nearly twice as much.
https://www.summitracing.com/parts/crn-283951?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-crane-cams&gclid=Cj0KCQjwhrzLBRC3ARIsAPmhsnU0u54qydmvH3kgPclzar4EixRF9nyONKDNg0eySh9VIuf6FmIYCaIaAusEEALw_wcB
Discussion Starter #19
BigD / Jim - In terms of what I will do, I am going to go with the #16 heads and try to keep my rebuild costs as low as possible.
Again, quick summary of the car: a tri power, with #16 heads (high compression), Doug's headers, 4 speed manual with a 3.55 rear end ? The popular cams that keep coming up are:
1. 068
2. Lunati 262 / 268 https://www.lunatipower.com/voodoo-hydraulic-flat-tappet-cam-pontiac-v8-262-268.html
3. Lunati 301 / 313 https://www.lunatipower.com/factory-performance-hydraulic-flat-tappet-cam-pontiac-v8-301-313.html
4. Summit Racing 2801 https://www.summitracing.com/parts/sum-2801/overview/
5. Summit Racing 2802 https://www.summitracing.com/parts/sum-2802/overview/
I'm going to take apart the heads this weekend and see what I have in the way of springs and valves.
I apologize for being indecisive, but I think with your help I have a good plan in place.
Thanks again for all of your help!
"...try to keep my rebuild costs as low as possible..."
That narrows it down to a Summit cam.
2801 can get by with cheaper springs, such as those sold by Paul Spotts, for just under $80, and the Comp Cams 988-16 springs that are just over $80 from some vendors.
https://www.ebay.com/itm/Pontiac-V8-stock-valve-springs-400-455-389-350-428-GTO-Firebird/283583622848?epid=672937061&hash=item4206e6aec0:g:LYAAAOSwmrlU0mJ9
https://www.ebay.com/p/192751619?iid=163851264296&chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=163851264296&targetid=541454196612&device=c&mktype=pla&googleloc=9025480&poi=&campaignid=6470549460&mkgroupid=81274343007&rlsatarget=pla-541454196612&abcId=1139336&merchantid=101503623&gclid=CjwKCAjwibzsBRAMEiwA1pHZrr0PhcF_nk1x4lnHyS-SzLwCslkranaLVPUIoZEEvYVx1Krx0f2mDxoC9S8QAvD_BwE
The 2802 will require stronger springs, such as the Paul Spotts springs that are just under $100, or the Crower 68404-16 springs which are around $130.
https://www.ebay.com/itm/VSH3-Pontiac-PERFORMANCE-valve-springs-400-455-389-350-428-GTO-Firebird/273969800936?hash=item3fc9df66e8:g:hvgAAOSwB4NW0LgK
https://www.summitracing.com/parts/cro-68404-16?seid=srese1&gclid=CjwKCAjwibzsBRAMEiwA1pHZrmAwn_w_Pc1yn8YpH4ogaROlqPE14Vmh_UXEj3vHsy_NnvWFplzCJxoCPlUQAvD_BwE
I bought the Jegs lifters, because they are said to be USA made, & were the cheapest USA made lifters I could find. Delphi made lifters were in the box. If anybody knows of cheaper USA made lifters, please post that info.
https://www.jegs.com/i/JEGS/555/20702/10002/-1
Hylift Johnson HFT Pontiac lifters are also made in the USA. (NOT Johnson, buy only Hylift Johnson brand)
1 - 20 of 22 Posts
