KSPORT big brake kits provide the ultimate in stopping power for your vehicle. Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking. These brake systems are designed for easy installation with minimal tools required (in most applications).
Our extreme lightweight caliper comes in differential bore configuration. It is machined from aircraft quality billet, weighs just over 5lbs. each, and has machined in protection grooves for the bridge tubes. Aluminum pistons, high temperature seals, and stainless steel brake pad wear plates are also standard on each caliper design. The opposed piston caliper design greatly improves pad wear and caliper rigidity over the OEM design. The stainless steel brake lines stop expansion under pressure.
Most applications utilize the 2-piece floating disc assembly, which reduces weight both rotating and unsprung. The floating disc also stops
Key Features:
•4. 6 or 8 Piston ProComp or Sport Comp Aluminum calipers
•D.O.T. Compliant Stainless steel brake lines
•Machined aluminum hats
•Carbon steel brackets
•Ventilated discs
•Certain size wheels required based on disc size
•High quality Ksport SC5 street brake pads (RC1 race pads available for additional cost)
•Slotted Rotors are standard but Cross Drilled Rotors are available upon request.
•Calipers come standard in Painted Orange - Painted Red, Painted Yellow and Anodized Black upon request.
•Each Kit is custom manufactured so expect a 2 to 4 week wait
FRONT:
2004 ~ 2006 - - Front ProComp 8 Piston Big Brake Kit - Diameter: 13 inch
2004 ~ 2006 - - Front ProComp 8 Piston Big Brake Kit - Diameter: 14 inch
2004 ~ 2006 - - Front SuperComp 8 Piston Big Brake Kit - Diameter: 15 inch
2004 ~ 2006 - - Front SuperComp 8 Piston Big Brake Kit - Diameter: 16 inch
GO TO NOPI KSPORT Catalog for model specific images and details
Contact the salesmen below or PM me for our best deal on KSPORT Big Brake Kits
