Hello All,
I have a 06 and last night i went out to make sure my baby was locked. well when I went out the lights were on, so i open and locked it again, the fog lights stayed on and would not go off. the switch was if off. I had to remove the relay, took it in today they replace the headlight switch, stiil not fixed, any one had that trouble?:confused
As noted in your owner's manual:
Before leaving a manual transmission vehicle, fully press the clutch pedal in, move the shift lever into REVERSE (R), and firmly apply the parking brake. Once the shift lever has been placed in REVERSE(R) with the clutch pedal pressed in, you can turn the ignition key to LOCK, remove the key, and release the clutch.
There are also instances where the door jamb switch becomes corroded.
Hope that helps!
