Wondering if anyone else has this problem. I've read many threads about many electrical problems, but haven't seen this specifically. The dealer already replaced a part based on the technical service bulletin 040864018 FRONT DOOR LOCK WILL NOT UNLOCK OR WILL LOCK INTERMITTENTLY. It didn't work.
Here's what's it's doing (intermittant, but 3 days out of the last 7 I couldn't lock my car):
1 - Both doors are shut
2 - Hit lock on keyfob
3 - Passenger side lock goes down, drivers side doesn't
4 - Horn chirps 5 times (horn indicator is turned OFF)
5 - Alarm is engaged
6 - If you open the driver's door at this point, the alarm siren goes off.
Also had this happen:
1 - inside car, remove key from ignition
2 - both doors lock (mind you I'm still in the car)
3 - Horn chirps 5 times (the horn indicator is OFF)
4 - alarm is activated
5 - At this point, I'm locked inside my car with the alarm activated. I have to unlock the car from the INSIDE using my key.
Maybe I need a priest instead of a GM dealer? Anyone with the same problem and/or possible suggestions please reply!!
Thanks,
GTO girl
Thanks,
GTO girl
