I have a 65 GTO. 400 bored .060. Looking for an engine builder/tuner in SoCal. Hoping someone can point me in the right direction.
Also, if your 400 is bored .060 and needs a rebuild, you will need to source another block if machine work is required. .060" is pretty much the "last cut" on these blocks unless you want to run sleeves in each hole ($$$). Get on line and check it out. I think HO is in LA, and several others.
