Just got my Loudmouth installed tonight. Would have had it on last night, but spent a lot of time trying to get the silly rubber mounts on and finally gave up. Came in and checked this site for any hints available - found the one that said put them on the exhaust system first and after the pipe is in place connect to the frame mount. I can't stress enough how important this is!!! Trying to do it as the instructions say is next to impossible (unless you have some special tools?). It went on very quickly with the proper process - so quickly in fact that I had forgotten to put the clamps on first. After fighting with removing the rubber mounts, disassembling yet again, I put the clamps on and re-installed everything. If you use grease on the mounts and holes in the rubber, use something very light and slippery, such as white grease. WD40 is also good. The heavy wheel bearing grease I used first is not slippery enough to make it easy. Since we are having some nasty weather here, I did not want to take the car out, so all I got to hear is with it at idle and up to 2000 rpm. It was great and I don't think it is all that loud.
