So I inherited my brother's '69(400, TH400 with a stage 2 shift kit, limited slip 3.23 gears) last year after he passed away. It hadn't been on the road in 2 or 3 years.
I got it running after dropping the gas tank and cleaning it out and replacing all the soft lines, an oil change, tranny fluid change, radiator flush and new plugs. Had to swap out the Quadrajet for one my buddy had sitting on a shelf because of a stuck float(the one I put on it was from a mid-70's chevy truck, and it wasn't kicking down quite right under heavy throttle, but I'm going to rebuild the original before it hits the road this spring).
She ran fine after a good warming up, but about 1/3 of the time, after it was warm, the oil light would sometimes flicker and sometimes come on steady at idle. It would go off under acceleration. I don't have an oil gauge installed, although it's on the list of future upgrades.
I've researched it pretty well, and it seems I might have a gummed up oil passage. My question to you guys is this:is there anything I can try to get it unblocked other than tearing into the engine? I'm not ready for a pull/rebuild as it's not in the budget right now. Any flushes/additives you guys have had success with? Thanks in advance for the replies.
Eric
Eric
