All the others 5 X 4 .75707GTOLS2 said:I just Wanted to know if anyone knows if the lug spacing is the same as a Camaro, T/A WS-6 or a Corvette? those have the spacing of
5 X 3.75
anyone???
I thought the wheel was 48mm offset? :confusedGTODEALER said:The goat is a 5 x 120mm with a 40mm offset.
NO!!!!!!!!!! It is DEFINETLY 40mm!!!! :cheerssilvergoat05 said:I thought the wheel was 48mm offset? :confused
NO!!!!!!!!!!!!!! It DEFINETLY is NOT!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :cheersGTODEALER said:NO!!!!!!!!!! It is DEFINETLY 40mm!!!! :cheers
I'm not usually one to argue, but the stock wheels are 40mm offset! Where are you getting your info? I even used 38mm offset wheels from a BMW on my goat and they were slightly outward more than stock. Your source is incorrect.silvergoat05 said:NO!!!!!!!!!!!!!! It DEFINETLY is NOT!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :cheers
17" Wheel Size: 17" x 8"
Bolt Circle: 5 x 120mm
Offset: +48mm
GTO Hub Size: ~69.5mm (have seen 69.5mm and 69.6mm)
17" Tire Size: 245/45WR17
Manufacturer: BF Goodrich
Type: g-Force KDWS
Diameter: 25.7"
Just about every aftermarket wheel is 40 MM but not factory
You are right, 38mm will will stick it out further because the stock offset is 48mm. It is measured from the inside. By putting a 38 mm wheel on, you moved the wheel out by 10mm.GTODEALER said:I'm not usually one to argue, but the stock wheels are 40mm offset! Where are you getting your info? I even used 38mm offset wheels from a BMW on my goat and they were slightly outward more than stock. Your source is incorrect.
