On a 69 that came with the M21 4 speed, should the speedometer cable exit the driver side or passenger side of the transmission?? Thanks
Dug through some old 45mm pics, from a 34K mile Pontiac plant built '69 RAIV Judge that went to OH for in '93, speedo cable was drivers side. trans was orig vin stamped. I have ran across coming out te pass side, need to contact friend who has all numbers match Arlington RAIII Judge.
factory installed M20 (& 3.23 or 3.55 gears), will def have drivers side tail shaft speedo outlet, have rebuilt two '69 M20's.
