Much easier if you pull the spark plugs as you won't get the compression fighting you. If the belts are tight enough, you could spin it using the fan blades. Not a lot of room and make sure you don't put any tools into the radiator.
looking for any help on this cam it came out of a 74 455 .060 over also looking for information on where to find these pistons trw je20 455 0.60 0ver with cat rods
Hi all...Looking for Quadrajet Carb for a 70-455HO. Old carb is shot (it’s been rebuilt by prior owner and is not salvageable) and number tag is missing so not sure of the actual model number. Looking to buy or recommendation where to buy A replacement. Thanks
Y'all have been very helpful in so many ways and I thank you for that help. I'm asking a novice question that must have been asked before but I can't find it in my searches. Why did the early GTO valve covers have a peak on one end? I want to make this stroker 467 look original at first...
The starter motor off My 70 Canadian Judge RAIII is Stamped McKinnon-Delco #1107716 8M29 Made in Canada. Can anyne explain this date coding? I read that McKinnon Industries Limited became a part of General Motors of Canada in 1969. Some people think it is original, does anyne know for sure?
