Unfortunately it seems I need a new master cylinder after replacing everything else. I have disc on the front and drum on the back. Do I need a special Master Cylinder, Thanks for the help
Keiko,
You don't need anything special. Just pick up one from a local auto parts store. I will advise that you buy a new one and not a remanufactured. I just did my '69 a couple weeks ago and had 2 remanufactured one leak and I finally got a new one instead. It's well worth the cost, I think it was like $10 dollars more.
Good Luck,
Rob.
Keiko,
Good Luck,
Rob.
Hey thanks Rob. do I need the one with the round reservoir in front and the square in back ? the one I just took off had a 1.125 bore and a lot of them have a 1 inch bore dose it make a difference. Also would you happen to know if you can bleed the brakes without the car running. ?? Thanks for your help
Yes larger cavity in front for disc and small cavity in rear for drums. You can successfully bleed brakes without car running.
