i have a 68 Tempest that hasnt been started in years (15). engine was working and running before it was garaged. can anyone recommend someone to help getting started?
drain and replace all fluids and oil, drain the gas tank and flush the lines then put 5 gallons of fresh gas in, new battery, plugs and points, and vacuum lines then fire it up!!! It's a Pontiac, if it was running when put away it should run now...once you get it going spray some carb cleaner in it then diagnose from there...:cheers
