:agreeQSGTO said:It is normal to get some metal from the fluid when changing it. If any of it is larger than a peice of glitter, the gears are shredding and you should consider upgrading. If you are driving it hard, you should change the fluid every 5K miles. It is expensive, but cheaper than gears.
